[Gdal-dev] writing RPC data in NITF format?
Frank Warmerdam
warmerdam at pobox.com
Thu May 11 13:47:04 EDT 2006
Sarah Mulholland wrote:
> I have a NITF image and RPC data in a separate file. I need to embed
> the RPC data in the NITF file. I see that there's a GDALExtractRPCInfo
> function. Would it be straightforward to create a GDALInsertRPCInfo so
> that I can perform the following steps:
> 1. populate a GDALRPCInfo object with the RPC values
> 2. read the NITF image into a GDAL data set
> 3. insert the RPC information
> 4. write the result to a NITF file
> Is this straightforward to do?
Sarah,
I'm not convinced that it would be all that easy. Currently the
GDAL NITF writer does not write any TREs (extensions) so a bunch of
machinery would need to be added. My next concern would be that we
are still not producing a proper "product" matching an existing product
specification though that might not really matter.
One option you might want to look into is writing NITFs with RPCs using
OSSIM. Generally speaking, I think the OSSIM folks have been doing more
indepth NITF support than I do in GDAL. I don't really want to replicate
all the more exotic stuff they do.
But of course, if it is important enough to you, it can be accomplished.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
