[Gdal-dev] ogr gml driver
Peter Rushforth peter.rushforth at gmail.com
Thu May 18 06:46:08 EDT 2006
Good day,
I've found that the using the gml driver to generate
mapinfo tab and esri shp files generates large .dat and .dbf
files respectively, because string fields are created with
254 characters.
Is there any way to specify the length of the character
fields prior to creation using an option or something?
Cheers,
Peter
