[Gdal-dev] Subtracting images
Thu May 18 16:31:01 EDT 2006
Morten Nielsen wrote:
> Is it possible to subtract two images from each other using GDAL?
> I have a large virtual raster covering a wide area, and several smaller
> base-images.
> I want to create a difference image where the part of the virtual raster
> that covers the base-image is subtracted from the base-image. Output
> should be the absolute difference in each band. The images are all
> georeferenced and have the same resolution. Are there any commandline
> tools available for this?
Morten,
There are no pre-built commandline tools for this.  You could write a
Python script using GDAL to load the data into Numeric arrays, and then
subtract them and save to a new GDAL file.  That process should be
pretty straight forward.
The FFT script might be a useful, if slightly overcomplicated, example of
how to do something similar.
   http://www.gdal.org/srctree/pymod/samples/fft.py
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
