[Gdal-dev] Raster data test suite
Ray Gardener
rayg at daylongraphics.com
Thu May 18 17:41:50 EDT 2006
It would be good to build a comprehensive data sheet on the drivers.
There is some info on the website, but each driver is described in its
own way. I've been making a spreadsheet to catalog their attributes and
would be happy to share that.
>> What do you mean as automated fashion?
Say I built GDAL and wanted a script that would exercise all the
drivers. Given a standard set of data files, the test program emits
certain things (attribute lists, images, dems) that can then be compared
(again by machine) against a reference set. For the Lev and Terragen
drivers, for example, I'm going to add sample data, along with a small
console app (or maybe use an existing GDAL util) and the reference
transformed data, and then a (windows) test script could add these lines
to itself:
testapp -lev frmts/leveller/sample.ter -gtiff out.tif
fc /b out.tif frmts/leveller/out.tif
testapp -gtiff sample.tif -lev out.ter
fc /b out.ter frmts/leveller/out.ter
As an app developer just enabling the data formats to increase the I/O
possibilities for end users, it's off-domain for me to get intimately
familiar with the formats (which would also defeat the abstraction
concept of the library). So an automated test suite is vital. This will
only become more so as more drivers are added. It's especially useful if
making changes to code shared by multiple drivers; one could catch side
effects that a simpler test would miss. By hooking CPLMalloc/Free the
test might also detect memleaks, and it could do benchmarking.
The above example requires a standard "sample.tif" GeoTIFF file, and
exercises only a one-to-many driver relationship, but if more standard
samples are added, you can get a many-to-many test working.
Basically, driver authors would be told, on top of the driver, you need
to run a test using the standard data, and include your driver's
conversion of it.
Ray
