[Gdal-dev] installing gdal
Christine Spietz
spietz at fh-bingen.de
Fri May 19 03:14:04 EDT 2006
Hi all,
originally I wanted to use the java-swig bindings (and I still want to) but
also after lots of help from the list (thanks to Ben and Frank) I was not
able to install.
So we decided that it might be the best to start the installation right new
at the beginning. But I still can't do it. Here the things I did and what
happened:
a.. Download daily snapshoot: http://dl.maptools.org/dl/gdal/daily/:
gdal-cvs-2006.05.18.tar.gz
b.. unzip/tar in the gdal-home-directory (=GDAL_HOME) =>
/usr/lib/gdal/gdal-cvs-2006.05.09
c.. in GDAL_HOME/swig/java/java.opt JAVA_HOME set right
d.. GDAL_HOME> ./configure (=> z.b. Eine Datei GDAL.opt aus GDAL.opt.in)
e.. GDAL_HOME> make
#####################error-log
g++ .... .libs/ogrgeometryfactory.o
In file included from ogrgeometryfactory.cpp:127:
ogr_geos.h:47:22:error:geos_c.h: No such file or directory
ogrgeometryfactory.cpp: In static member function static
OGRGeometry*OgrGeometryFactory:createFromGeos(GEOSGeom_t*):
ogrgeometryfactory.cpp:839: error:GEOSGeomToWKB_buf was not declared in this
scope
make[1]: ***[ ogrgeometryfactory .o] Error 1
make[1]: Leaving directory '/usr/lib/gdal/gdal-cvs-2006.05.18/ogr'
make: ***[ogr-target] Error 2
a.. GDAL_HOME> ./configure -help =>
a.. GDAL_HOME> ./configure --with-geos=yes
b.. GDAL_HOME> make
/usr/bin/sed: can't read /usr/lib/libjpg.la: No such file or directory
libtool: link: '/usr/lib/libjpg.la' is not a valid libtool archive
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory '/usr/lib/gdal/gdal-cvs-2006.05.18'
make: *** [check-lib] Error 2
a.. GDAL_HOME> ./configure --with-geos=yes --with-jpeg=no
b.. GDAL_HOME> make
/usr/bin/sed: can't read /usr/lib/libjepg.la: No such file or directory
libtool: link: '/usr/lib/libjpeg.la' is not a valid libtool archive
a.. GDAL_HOME> ./configure --with-geos=yes --with-jpeg=internal
b.. GDAL_HOME> make
Getting the same error as before ;-(
Any idea what I am doing wrong?
Best regards
Christine
