[Gdal-dev] GDAL v1.3.2 on linux - no PGEO driver
Stuart Eve
stuarteve at lparchaeology.com
Fri May 19 05:17:16 EDT 2006
Mateusz,
Great to hear you've found the issue!
In terms of PGeo on linux - its not working that well/at all! Theres a
number of issues that I came across (after talking with Frank about it a
bit):
The system that I had it set up on is Suse 10, with unixODBC 2.2.10 and
I started out with mdbtools 0.5 and gdal 1.3.1
1. The PGeo is currently set up to look for a driver called Microsoft
Access Driver (*.mdb) - this of course doesn't exist by default (but it
may be possible to set a driver up in the odbcinst.ini - I was going to
try that but then upgraded my gdal and 'lost' the pGeo driver)
2. I set up a new driver (in odbcinst.ini) called MDBToolsODBC - and
pointed it at the mdbtools driver (libmdbodbc.so.0)
3. I then went into the source code and changed
ogr/ogrsf_frmts/pgeo/ogrpgeodatasource.cpp Line 104 to read: sprintf(
pszDSN, "DRIVER=MDBToolsODBC;DBQ=%s", pszNewName).
4. I ran ogrinfo (pointing it at my geodatabase) and Bingo it connected!
However, I then got a message saying that 'table GDB is not a table'. It
turns out that the current stable version 0.5 of mdbtools has a bug in
it that doesn't recognise underscores in table names - so all of the GDB
tables were getting rejected!
5. I upgraded my mdbtools to 0.6 - the CVS version (with the underscore
bugfix) - and then at the same time upgraded my gdal and hence lost the
PGeo driver - so haven't been able to test a PGeo connection. However, I
can now read the geodatabase using the ODBC driver and list the tables,
etc. so the underscore bug is definitely fixed. So close!!
Ok since starting this email I have just set up a driver in my
odbcinst.ini called [Microsoft Access Driver (*.mdb)] and ran an ogrinfo
ODBC:/path/to/geodb and it connected just fine (but of course didn't
recognise it as a geodatbase - but the ODBC connection read it).
So in conclusion (sorry for long email) - I think that if you manage to
get PGeo installing for gdal1.3.2 - all a linux user would have to do to
get it to access geodatabases (at least with unixODBC) is to install
mdbtools 0.6 and set up a Driver in their odbcinst.ini called [Microsoft
Access Driver (*.mdb)] pointing at libmdbodbc.so.0.
So I look forward to your bugfix so I can try it out!
Cheers Stu
Mateusz Loskot wrote:
> Stuart Eve wrote:
>> Apologies for cross-posting! I am currently working through a method
>> of accessing personal geodatabases from a linux platform. I have now
>> upgraded my gdal to 1.3.2, but the PGeo driver doesn't seem to be
>> available anymore. It was available to me on 1.3.1 - are there any
>> special flags I need to use when compiling? And if not is there a way
>> to rollback to 1.3.1 (I know there is no 'make uninstall'
>> (bug 133)).
> Hi Stuart,
> I found some minor issue in building configuration that seems to be
> causing this problem.
> I'm working on it to fix.
> But I'd need your assistance with PGeo driver.
> First, as I know ODBC on Linux is not working well and this subject need
> to be checked. PGeo as dependant on ODBC, seems to also need to be checked.
> So, could you provide me with some details about how PGeo was running on
> Linux? Have you noticed any problems? Was it running stable?
> If you'd have any comments, please share them all :-)
> Cheers
Stuart Eve
L - P : Archaeology
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060519/439bd1a2/attachment.html
