[Gdal-dev] Python Problem
Norman Vine
nhv at cape.com
Fri May 19 14:12:05 EDT 2006
Christopher Condit writes:
> Here's a better piece of code illustrating the problem I'm having:
> bands=[]
> for timeSlice in range(60):
> file = "C:\\develop\\brewin\\vel-%i.tif" % timeSlice
> dataset = gdal.Open( file, GA_ReadOnly )
> bands.append(dataset.GetRasterBand(1))
> for iter in range(len(bands)):
> #The following line prints correctly (720x330)
> print "Dimension: (%i, %i)" % (bands[iter].XSize, bands[iter].YSize)
> #The following line throws
> #TypeError: Access window out of range in RasterIO(). Requested
> #(0,0) of size 720x1 on raster of 65x16.
> line = bands[iter].ReadAsArray( 0, 0, bands[iter].XSize, 1 )
> Thanks for any help,
## adapted from $GDAL/pymod/samples/rel.py
## untested
bands=[]
for band in bands:
print "Dimension: (%i, %i)" % (band.XSize, band.YSize)
for i in range( band.YSize - 1):
line = band.ReadAsArray(0, i + 1, band.XSize, 1, band.XSize, 1)[0]
HTH
Norman
