[Gdal-dev] CreateCopy or Create to fill with zeros?
Charles Wivell
Charles.Wivell at dnr.state.mn.us
Fri May 19 15:21:20 EDT 2006
Hi all;
Simple question... I have a very large Dataset and I want to copy it, except that, instead of copying the raster data, I want it filled with zeros. Can I use CreateCopy(...) with something set in the papzOptions.....? I know I can use Create(...), but I'm not sure if Create(...) zeros the disk space where the raster data is stored.
I'm programming in C++.
Thanks
Chuck Wivell
MN DNR
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
