[Gdal-dev] Ask: the error when I use gdalinfo.exe
Mateusz Loskot mateusz at loskot.net
Tue May 23 10:46:58 EDT 2006
lky wrote:
> Hi,all:
> I use the gdalinfo utility to test opening and reporting of the jdem format as the article "GDAL Driver Implementation tutorial" said. But I met the following error, I don't know why this happen. I hope your help.
> Command line : gdalinfo jdem
Is 'jdem' above a dataset present on your filesystem?
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
