[Gdal-dev] does gdaltindex support MapInfo GIF+GIF format?
Tue May 23 11:10:15 EDT 2006
Zhonghai Wang wrote:
> Hi guys,
> I've posted this question in the MapServer list, but I did not get any
> reasonable solution, I'd like to post it here again, hope somebody
> can give me some clues.
> I have a subfolder of GIF raster image, and each GIF file has a
> corresponding TAB file, which specifies the coordinate information for
> the GIF image, the content of the TAB is something like this:
> !table
> !version 300
> !charset WindowsLatin1
> Definition Table
>   File "m_1_1_1000.gif"
>   Type "RASTER"
>   (5.290517,48.2308475) (1392,987) Label "Pt 1",
>   (5.25001439194036,48.25) (0,0) Label "Pt 2",
>   (5.25001439194036 ,48.211695) (0,1974) Label "Pt 3",
>   (5.33101960805964,48.25) (2784,0) Label "Pt 4",
>   (5.33101960805964,48.211695) (2784,1974) Label "Pt 5"
>   CoordSys Earth Projection 1, 104
>   Units "degree"
> but if I perform the gdaltindex command to create a tile shapefile for
> the images, an error occurs:
>  >>no georeferencing info available for the images file, performance
> will be skipped.
> and I also get some info from the "Raster Data Access" document, "The
> only way to georeference GIF files is with a world file. ", is it really
> so?if it's true, there will be a huge project for me to change all the
> TAB files.
> hope that someone can help.
> thanks so much for any info.
Zhonghai,
As I think was explained on the mapserver list, GDAL does not currently
support mapinfo tab files as a source of georeferencing for raster files.
So you will need to manually or by script create world files for from the
.tab files.
Good luck,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
