[Gdal-dev] Google Earth Data retrieval
Matt Wilkie matt.wilkie at gov.yk.ca
Thu May 25 13:10:15 EDT 2006
Mateusz Loskot wrote:
> Nikolai Vladychevski wrote:
>> We
>> will be using it for private use, just like we can use
>> now Google Earth as standalone application.
> But you will broke copyrights and licensing agreement using Google
> images that way!
> It's said, that you are allow to access those data only with GE, so
> if you'll use third-party software not mentioned in the agreement, then
> you obviously broke the agreement.
On the other hand, NASA World Wind is not subject to the same
limitations, albeit it doesn't have access to the same higher quality data.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
