[Gdal-dev] Raster to vector conversion (polygons) script
Ari Jolma ari.jolma at tkk.fi
Thu May 25 18:00:51 EDT 2006
Hello,
I needed to make polygons from a raster but could not find either an
algorithm nor usable software from the net, so I made one up myself.
This one uses GDAL and OGR and their Perl interface. The script is on my
examples page: http://map.hut.fi/PerlForGeoinformatics/examples.html
The script first creates a data structure of the polygons in the raster
by going through it once scanline by scanline. Then the border of each
polygon is travelled and at the same time the outline of the polygon is
stored. Then each outline is stored as a polygon into an OGR layer.
The algorithm uses 8-connectedness but that could be changed to
4-connectedness quite easily. The "travelling the border and create
outline" algorithm is a bit cumbersome but I've used the border
traversal quite a bit, so it should be ok. Vectorizing large and complex
rasters may require quite a lot of memory. All areas in the raster are
stored as simple polygons, i.e., "holes" are not treated in any special
way, they end up as separate polygons into the layer. Projections are
not considered much. etc...
Let me know about bugs and possible enhancements.
Ari
