[Gdal-dev] gdal_rasterize - can't make it work
Christopher Barker Chris.Barker at noaa.gov
Thu May 25 19:38:01 EDT 2006
Maciek Sieczka wrote:
> I don't want to render my lines shapefile on a display in any fancy way.
> I want to properly turn into a raster (grid), at a given resolution, for
> further raster analysis within Grass.
well, at the very least, you'll need to specify how wide the lines are.
Maybe that's why only polygons are supported.
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT         (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
