[Gdal-dev] Raster to vector conversion (polygons) script
Ari Jolma
ari.jolma at tkk.fi
Fri May 26 02:15:26 EDT 2006
Aaron Racicot kirjoitti:
> Hi there Ari,
> Very cool...
> Another option is to just do the following in grass:
> r.in.gdal input=input_rast output=grass_rast
Funny how I did not think about looking at Grass. I did look, but only
after I sent the post. I took a look at r.in.gdal at CVS. The algorithm
there was not very clear to copy however, and I would love to use Grass
(I guess) if it could use, e.g., geotiffs directly. Or can it? I may
just be talking nonsense again. I tried once r.in.gdal for one of my
50000x50000 rasters and it was just unbearably slow.
Besides, it is educational and fun to discover and write comp.graphics
algorithms on holidays ;-)
Ari
> r.to.vect input=grass_rast output=grass_vect feature=area
> v.out.ogr input=grass_vect type=area dsn=out_dir olayer=out_name
> format=[ANY OGR FORMAT]
> You can see the documentation for r.to.vect at the following address to
> see if will do what you are after (or compare notes on methods used):
> http://grass.itc.it/grass61/manuals/html61_user/r.to.vect.html
> Aaron
> | Aaron Racicot | aaronr at ecotrust.org |
> | GIS Programmer | 503.467.0759 |
> | e c o t r u s t |
> | Jean Vollum Natural Capital Center |
> | 721 NW Ninth Avenue |
> | Suite 200 |
> | Portland, OR 97209 |
> | www.ecotrust.org |
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Ari Jolma
> Sent: Thursday, May 25, 2006 3:01 PM
> To: gdal-dev at lists.maptools.org
> Subject: [Gdal-dev] Raster to vector conversion (polygons) script
> Hello,
> I needed to make polygons from a raster but could not find either an
> algorithm nor usable software from the net, so I made one up myself.
> This one uses GDAL and OGR and their Perl interface. The script is on my
> examples page: http://map.hut.fi/PerlForGeoinformatics/examples.html
> The script first creates a data structure of the polygons in the raster
> by going through it once scanline by scanline. Then the border of each
> polygon is travelled and at the same time the outline of the polygon is
> stored. Then each outline is stored as a polygon into an OGR layer.
> The algorithm uses 8-connectedness but that could be changed to
> 4-connectedness quite easily. The "travelling the border and create
> outline" algorithm is a bit cumbersome but I've used the border
> traversal quite a bit, so it should be ok. Vectorizing large and complex
> rasters may require quite a lot of memory. All areas in the raster are
> stored as simple polygons, i.e., "holes" are not treated in any special
> way, they end up as separate polygons into the layer. Projections are
> not considered much. etc...
> Let me know about bugs and possible enhancements.
> Ari
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
