[Gdal-dev] KML Write-only driver for OGR
Christopher Condit
condit at sdsc.edu
Fri May 26 15:11:15 EDT 2006
Hi Guillaume-
A separate GDAL driver for dealing with KML and rasters would have to be implemented to accommodate this request. I have a general idea of how GE/rasters work - but there are a few particulars that I don't understand (ie - how to best tile images onto GE?). It strikes me this could be more in line with creating a world file for a raster image. If someone can spec out the process I think creating the actual KML file should be trivial...
-Chris
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Guillaume HUBY
Sent: Friday, May 26, 2006 12:41 AM
To: 'Frank Warmerdam'; 'gdal-dev'
Subject: RE : [Gdal-dev] KML Write-only driver for OGR
Hello,
> -----Message d'origine-----
> De : gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] De la part de
> Frank Warmerdam
> Envoyé : mercredi 24 mai 2006 23:48
> À : gdal-dev
> Objet : [Gdal-dev] KML Write-only driver for OGR
> As I see it the downside is that this driver is write-only,
> which isn't a concept that is particularly well handled by
> OGR (there is not way for
> a driver to indicate it is write only currently). However,
> we have done
> this for GML, and DWG/DXF in the past so it isn't a new thing.
I think it would be great to be able to read kml too. When using GE, you can
export features into kml. If you have GE pro edition, you can draw features
and save them into kml. These are examples where reading is interesting.
I would also like to raise a new question. KML is also made for displaying
rasters into Google. Would this driver being able to make this.
An interesting link not mentionned in this thread:
http://earth.google.com/kml/
Thanks for all this job,
Guillaume.
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
