[Gdal-dev] ogr geometry intersection
Didrik Pinte
dpinte at itae.be
Mon May 29 10:58:29 EDT 2006
Reading the doc, I'm wondering what's the behaviour of the
OGRGeometry.Intersection method.
When two polygons intersects, will the resulting object be a Polygon or
a MultilineString ?
Is there a way to be sure that the result of the intersection is a line
and not a surface ?
I can explain my problem in more details if needed.
Anyway, thank you in advance for the help,
Didrik
Name: not available
Desc: Ceci est une partie de message
=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060529/823bd6e8/attachment.bin
