[Gdal-dev] tiff to jp2ecw
Mark Overmeer
mark at overmeer.net
Mon May 29 11:18:08 EDT 2006
Dear Frank,
* Frank Warmerdam (warmerdam at pobox.com) [060529 14:30]:
> > gdal_translate input.tif -of JP2ECW -ot Byte -co TARGET=0 output.jp2
> >However... there are two problems:
> > (1) the input.tif (geotiff) contains 6 images, created with
> > geotifcp [123456].tif input.tif
> > however, the resulting output.jp2 contains only one image (the first)
> Basically GDAL treats GeoTIFF as a one-image-per-file format.
> If you wanted the six images treated as bands of a single image then
> you could use a different mechanism to merge the bands. Let me know if
> that was your desire.
Yes, that is (probably) what I need. Six bands in one image of six images
in one file.... probably both work. How can I achieve the former?
> > (2) "gdalinfo output.jp2" says:
> > Driver: JP2KAK/JPEG-2000 (based on Kakadu)
> > where I expected JP2ECW
> This is not a problem. The result is a JPEG2000 file, and FWTools
> includes more than one JPEG2000 driver, naming the JP2ECW driver, ...
Ok, now I understand: the specified driver is not the one which produced
the image but is the one who reads the image.
Thanks for your help!
CU,
MarkOv
