[Gdal-dev] invalid/no projection information in output TAB
formatfiles
Peter.Rushforth at statcan.ca
Mon May 29 13:44:43 EDT 2006
I'm using gdal 1.3.2 , built on solaris 8 by me,
with an additional local tweak for gml data sources.
Peter
> -----Original Message-----
> From: Richard Matsunaga [mailto:richard.matsunaga at waypointinfo.com]
> Sent: May 29, 2006 1:13 PM
> To: Peter.Rushforth at statcan.ca; gdal-dev at lists.maptools.org
> Subject: RE: [Gdal-dev] invalid/no projection information in
> output TAB formatfiles
> What version of GDAL/OGR are you using?
> There was a bug with MapInfo files and projections that was
> fixed in the latest release.
> Richard
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
> Sent: May 29, 2006 12:02 PM
> To: gdal-dev at lists.maptools.org
> Subject: [Gdal-dev] invalid/no projection information in
> Hello list,
> I am using ogr2ogr to convert gml files to mapinfo TAB
> format, using the following command option and syntax:
> ogr2ogr -a_srs WGS84 -f "MapInfo File" test.map test.gml
> The test.map and associated files are created, but the
> projection about the layer is not set correctly and Mapinfo 7
> crashes when exiting if the file is not closed first, a concern.
> When I go through MIF format, and then to TAB, the projection
> info is correctly set in the TAB file and no problems with
> Mapinfo are encountered:
> ogr2ogr -a_srs WGS84 -f "MapInfo File" -dsco FORMAT=MIF
> temp.mif test.gml ogr2ogr -f "MapInfo File" test.tab temp.mif
> So first converting to mid/mif, then to tab is an option, but
> is there some way to skip that step?
> Thanks for any advice,
> Peter
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
