[Gdal-dev] Re: GDAL Coding Guidelines
Frank Warmerdam
warmerdam at pobox.com
Wed May 31 10:23:57 EDT 2006
Mateusz Loskot wrote:
> Hi Frank,
> Today, I was talking a bit with Dronk and asking him if using STL in
> GADL is recommended or not.
> I was asking because I'm quite confused and I don't know how should I
> move on with some applications.
> Here are examples of some of my questions:
> Can I use <sstream> library instead of sprintf,strcat, memcpy, etc.?
Mateusz,
Please do not.
> Can I use string instead of C-like strings, when it's applicaple?
You should use CPLString (a slightly extended std:string with a
Printf() method for formatted "printing" into the string. Try not to
go wild using esoteric std:string methods as some day I may restructure
CPLString to not derive from std:string, but still to provide similar
(if somewhat simplified) services.
> e.g. concatenating strings with <sstream> would take a few line of code,
> but with C-like approach, it takes much longer and IMHO is more bugs
> prone. This is just an example.
I am generally anti-streams, and have avoided their use in GDAL. I
would prefer to keep that approach though if you could demonstrate
a compelling value I might reconsider.
> As you know, C++ is my favourite language but that's not
> thecase here. I also can code in C, I'm flexible ;-)
> I just would like to suggest the GDAL PCS to develop some coding
> guidelines or convention, that developers could follow.
> You know, C and C++ are different languages and some guidelines would
> help developers to avoid potential confusions.
I agree that a guidelines RFC would be appropriate. I'm just not all that
keen on writing it. I'm putting this email out to the gdal-dev list for
further input but I will start working on a coding guidelines RFC.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
