[Gdal-dev] Python/OGR SHAPE creation: prj file missing
Markus Neteler
neteler at itc.it
Wed May 31 17:12:23 EDT 2006
Frank, Matthew,
cool, works!
Markus
On Wed, May 31, 2006 at 01:20:50PM -0700, Matthew Perry wrote:
> Markus,
> I usually cheat and just copy and existing .prj from a dataset with
> the same projection. But it can be accomplished other ways as well.
> If it's just an EPSG code, there the epsg_tr.py utility:
> epsg_tr.py -wkt 4326 > ${shapefile_prefix}.prj
> Or if you want to do it within a python script:
> srs = osr.SpatialReference()
> srs.ImportFromProj4(.....)
> ## Or for EPSG codes
> srs.ImportFromEPSG(int(....))
> prj = srs.ExportToWkt()
> ## write the prj string to the appropriate file
> - Matt
> On 5/31/06, Markus Neteler <neteler at itc.it> wrote:
> >Hi,
> >I was writing a simple Python script to generate a
> >SHAPE file following
> > http://www.perrygeo.net/wordpress/?p=4
> >(thanks, Perry!).
> >The SHAPE related files are created, but the .prj file not.
> >How to enable that?
> >thanks
> > Markus
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/gdal-dev
> Matt Perry
> perrygeo at gmail.com
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
