[Gdal-dev] projection info in mapinfo tab files corrupt when
specifying -a_srs or -s_srs and -t_srs in ogr2ogr
Frank Warmerdam
warmerdam at pobox.com
Wed May 31 23:08:26 EDT 2006
Daniel Morissette wrote:
> This may be related to a bug in the MITAB library which is used by OGR
> to read/write TAB files:
> http://bugzilla.maptools.org/show_bug.cgi?id=1319#c7
> See also:
> http://bugzilla.maptools.org/show_bug.cgi?id=1254
> Perhaps try rebuilding gdal/ogr/ogrsf_frmts/mitab with
> -DMITAB_AFFINE_PARAMS (and then relink ogr2ogr) and see if the crash
> goes away.
Daniel,
Should I be changing GDAL to build mitab this way? Is there a reason this
isn't the default?
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
