[Gdal-dev] RFC 3: GDAL Commiter Guildlines
Marek Brudka mbrudka at aster.pl
Wed Nov 1 06:04:49 EST 2006
Practice:
"When committing new features or significant changes to existing source
code, the committer should take reasonable measures to insure that the
source code continues to build and work on the most commonly supported
platforms (currently Linux and Windows), either by testing on those
platforms directly, running buildbot tests, or by getting help from
other developers working on those platforms."
sounds good, but is rather impractical. SVN is a kind of "communication
medium" between developers and operating systems. Moving manually files
between Linux/Windows to make tests as well as sending/receiving sources
to/from developers always lead to troubles with versions/line ends etc.
Moreover, efforts related with "new features or significant changes"
usually require a lot of additional work which should be versioned by it
own. A common practice for this case is to create and work on a private
branch in repository. I propose then to modify the recommendation in the
following way:
"New features or significant changes to existing source code should be
commited to separate private branches. Merging to the main trunk is
allowed only after testing them by separate developers on various
platforms."
BTW. I do not think, that the requirement to have all branches
compilable and valid is reasonable. It is enough the have good sources
in the main trunk and/or in some important public branches.
Marek
