[Gdal-dev] RFC 3: GDAL Commiter Guildlines
Daniel Morissette
dmorissette at mapgears.com
Wed Nov 1 11:07:44 EST 2006
Marek Brudka wrote:
> "New features or significant changes to existing source code should be
> commited to separate private branches. Merging to the main trunk is
> allowed only after testing them by separate developers on various
> platforms."
Ouch... I don't want to imagine what the SVN repository will look like
in a few years if we keep creating private branches for everything. Even
just one private branch per committer (and likely per committer per
software release) is likely to lead to quite a mess. That's assuming I
understood Mateusz' explanation right and branching indeed means
duplicating the whole directory tree on the server. (As I wrote before,
in CVS a branch is just a tag and the cost IMO is lower than full
duplication of everything so that would be less of an issue.)
Is it really common practive with SVN-based projects to create private
branches and merge like this? Is this not abusing the features of the
source code management system? Is there a way to physically delete a
private branch from the SVN server and remove any trace from it in order
to keep the repository clean?
Just thinking out loud...
Daniel
Daniel Morissette
http://www.mapgears.com/
