[Gdal-dev] GeoTIFF and CCITTRLE compression
Markus Neteler
neteler at itc.it
Thu Nov 2 12:01:17 EST 2006
I was asked to fix some ArcInfo generated TIF/TWF files
to Geotiff to include the projection info.
Original header:
Driver: GTiff/GeoTIFF
Size is 26508, 22992
Coordinate System is `'
Origin = (1680792.312782,5091252.448363)
Pixel Size = (0.25000000,-0.25000000)
Metadata:
AREA_OR_POINT=Point
TIFFTAG_SOFTWARE=Arc/Info
TIFFTAG_XRESOLUTION=0.039000001
TIFFTAG_YRESOLUTION=0.039000001
TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
Image Structure Metadata:
COMPRESSION=CCITTRLE
Corner Coordinates:
Upper Left ( 1680792.313, 5091252.448)
Lower Left ( 1680792.313, 5085504.448)
Upper Right ( 1687419.313, 5091252.448)
Lower Right ( 1687419.313, 5085504.448)
Center ( 1684105.813, 5088378.448)
Band 1 Block=26508x3 Type=Byte, ColorInterp=Palette
Metadata:
NBITS=1
Color Table (RGB with 2 entries)
0: 255,255,255,255
1: 0,0,0,255
Using
gdal_translate -a_srs EPSG:26591 -co COMPRESSION=CCITTRLE ...
does not quite work since CCITTRLE isn't supported (AFAIK).
Also the color table is expanded a lot to 0..255.
My questions are:
- how to compress in a similar way (since we cannot preserve CCITTRLE)?
- is the color table expansion harmful (it looks ok, but will it be
understood everywhere)?
thanks,
Markus
