[Gdal-dev] C# Bindings
Frank Warmerdam
warmerdam at pobox.com
Sun Nov 5 13:18:22 EST 2006
Simon Perkins wrote:
> But more significantly, if we're going to have versons of
> Read/WriteRaster() that use arrays as buffers, then you can't do pointer
> arithmetic with the array variable. So the only way to work with packed
> pixel buffer formats (i.e. "pixel interleaved" / BIP formats) is to
> specify a bufferOffset. What do you think?
Simon,
I see you point. I had missed this whole distinction between higher and lower
level api.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
