[Gdal-dev] GDAL building for Windows CE
Mateusz Loskot
mateusz at loskot.net
Mon Nov 6 07:39:22 EST 2006
kiruba nantham wrote:
> Hai Frank,
> I am kiruba, i had completed my s57 file reader(ENC file format)
> sucessfully.
kiruba,
S57 driver is not available for Windows CE yet.
> Now i am trying to build *gdal13.dll* to work for pocket PC
> 2003(*WINDOWS CE*) but i am getting following errors.
What GDAL version do you use?
There are some issues in 1.3.2, so it's recommended to use GDAL from CVS
to build it for Windows CE.
> 1) When i am compiling from command prompt i am able to set
> environment
> and i checked for *Platform* and *OSVersion* as you
> explained i am
> getting same that is *POCKET PC 2003* and *WCE420*. but when i am
> doing *nmake /f makefile.evc4 *i am getting this errors.
> cannot open include file windows.h
> cannot open include file stdio.h
You've likely not configure your environment as described in secton
"Building GDAL port using eVC++ and makefiles", step 2nd, in this howto
http://gdal.org/wince.html
> 2)Then i tried to build evc4_gdalce_dll.vcw *using embedded VC++ 4.0*
> i was getting around 95 errors. after including paths finally
> i am getting
> 22 errors, some errors are
> i) error C2065: 'wce_findfirst' : undeclared identifier.
> ii) error C2065: 'wce_findnext' : undeclared identifier.
> *etc... *
> i attached the full error report with this mail, if it is
> possible check this out.
This is one of the issues I mentioned, so GDAL CVS is recommended.
While GDAL 1.3.2 was releasing, in port for Windows CE functions naming
has changed, the wce_ prefix was changed to wceex_ because of names
clashes with MFC functions.
For Windows CE port, GDAL 1.3.2 should be considered as alpha version.
So, please use GDAL from CVS.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
