[Gdal-dev] gdal tool for generating statistics on geotiff?
John Cartwright
John.C.Cartwright at noaa.gov
Tue Nov 7 18:38:43 EST 2006
Thanks Frank, that was exactly what I was looking for!
Out of curiosity, is that option documented anywhere? I didn't see it.
-- john
Frank Warmerdam wrote:
> John Cartwright wrote:
>> Hello All,
>> is there a gdal tool that will allow me to generate statistics (min,
>> max, etc.) on the values in a geotiff?
> John,
> The -stats option to gdalinfo should report stuff like the following:
> Band 1 Block=512x16 Type=Byte, ColorInterp=Gray
> Minimum=0.000, Maximum=255.000, Mean=104.135, StdDev=58.308
> Metadata:
> STATISTICS_MINIMUM=0
> STATISTICS_MAXIMUM=255
> STATISTICS_MEAN=104.13526916504
> STATISTICS_STDDEV=58.308455229198
> Best regards,
