[Gdal-dev] Calculating Polyline lengths in a file
matt.pettis at thomson.com
Wed Nov 8 11:14:02 EST 2006
I also received an email about determining units of the output by the SRS... as I am a newbie, can anyone point me to how I use the SRS (I assume it can be gleaned, or is the sum total of what is in the .prj file) to get my units?
tia,
matt
From: gdal-dev-bounces at lists.maptools.org on behalf of Rob McCulley
Sent: Tue 11/7/2006 4:48 PM
To: gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] Calculating Polyline lengths in a file
I needed to do this recently. I wound up using python mapscript. Here
is a snippet of the code that did it for me:
shpfile = mapscript.shapefileObj(gpsfilelocation)
totalLength = 0
for i in range(shpfile.numshapes):
shp = shpfile.getShape(i)
length = shp.getLength()
totalLength = totalLength + length
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
Sent: Tuesday, November 07, 2006 3:27 PM
Subject: [Gdal-dev] Calculating Polyline lengths in a file
Is there an easy way to calculate the lengths of polyline objects in a
shapefile (i have a shapefile of roads for a county, and want to find
the total length)? Is there an OGR tool to do this, or does anybody
know of another tool?
I have done this halfway a hard way... I imported my file into
PostgreSQL/PostGIS, and applied length2d to it, and got a number.
However, I can't find documentation for what the units of the result are
in. Does anybody know the answer to this question as well, as long as I
am here?
TIA,
Matt
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
MailScanner thanks transtec Computers for their support.
