[Gdal-dev] C# Bindings
Simon Perkins
sy at perkins.net
Wed Nov 8 19:15:18 EST 2006
On Thu, 9 Nov 2006 00:11:31 +0100, "Tamas Szekeres"
<szekerest at gmail.com> said:
> I've added some of the typesafe overloads so you can make the comparison
> easily.
Thanks!
> Did you mean that the buffer offset parameter should be added only to
> the IntPtr overloads?
Actually, I think it's most important that the buffer offset parameter
(thinking about it, perhaps "startIndex" would be a better name) is
present in the array versions. For consistency, let's add it to all
versions.
Cheers,
Sy
