[Gdal-dev] errors with gdal-1.3.2 under MS Visual C++ 2003
Jean-Daniel GONON jdgonon at gi-lemans.com
Fri Nov 10 10:09:23 EST 2006
Hi all,
I had some problems with compilation of GDAL/OGR : problems are compatibility between "gdal13d.dll" (generated by GDAL/OGR) and ogrinfo.exe because none format (dgn, ...) is recognized.
So I start a new compilation with GDAL/OGR 1.3.2, compiled in command lines without errors.
I had to add " xerces-c_2_3_0-win32 " in gdal-1.3.2\frmts\ folder.
Now I have new errors in Visual C++ : " gdal error LNK2019: symbole externe non résolu _ObjectName référencé dans la fonction _ObjectFunction "
My configuration : gdal1.3.2 under MS Visual C++ 2003 (version 7).
I don't know what I can do ?
Thanck you
Jean-Daniel
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061110/533c4bdf/attachment.html
