[Gdal-dev] GDAL conflicts (copysign() and snprintf() )
Ozy Sjahputera sjahputerao at missouri.edu
Fri Nov 10 17:55:03 EST 2006
I am trying to build a C++ project that uses GDAL by including
gdal_priv.h, cpl_string.h, ogr_spatialref.h and gdalwarper.h.  The
project was initially created in a Linux environment (Gentoo) and was
running fine.  While the linux box is being rebuilt, I have to work
using an XP machine.  The project compiles and runs fine when built
using VC .NET (2003).  But it throws errors when built using MinGW (with
Eclipse CDT IDE).
The two functions cited for these errors are copysign and snprintf.
After some digging I found that cpl_config.h contains some constants
that indicates whether these functions are present.
I am guessing that the settings in cpl_config.h are designed to work
with VC++ libraries, but problems arises when one uses MinGW libraries.
Any idea how to resolve these conflicts?
Thanks
oz
