[Gdal-dev] GeoQuadTree - an open format
for storinggeoreferencedimages
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 15 10:07:44 EST 2006
Jordi Gilabert Vall wrote:
> I only wanted a lossless compression, so I chose PNG format for tiles,
> but many people also wants a lossless compression, so I'm going to
> support two types of compression, PNG and maybe JPEG or JPEG2000. I like
> the PNG format because with 4-bands PNGs (RGBA), the alpha channel
> allows me to store non-data pixels. With JPEG format, I would
> "sacrifice" a RGB color to represent non-data values. There is also the
> need of supporting multi-band images, this could be accomplished with as
> many PNGs as bands. These are small changes, I will try to make it on
> the next release.
> On the other side, I think storage space is not the big problem
> nowadays. I prefer more efficient algorithms in terms of CPU usage, than
> efficient in terms of storage space. If someone prefer the reduction of
> storage space, the wavelet compression approach could be preferred
> (LizardTech's MrSID, ER Mapper's...). I want the freedom to choose a
> simpler, efficient an FREE approach.
> GeoQuadTree handles a pyramid of overviews. When you create a
> GeoQuadTree image, you specifiy the number of levels in the pyramid.
> Every time you import a image into a GeoQuadTree, the utility builds the
> pyramid of overviews (only updates the tiles affected upside in the
> pyramid).
Jordi,
I would be interested in incorporating your geoquadtree gdal driver into
the mainline GDAL source tree, but I see that it is licensed under the GPL.
In the interest of simplicity of licensing I prefer to keep all the core
GDAL source tree to the MIT/X license already used. So, unless you are
interested in licensing the driver in a GDAL compatible form, I think it
will need to stay as a plugin.
I would like to see the XML metadata file for geoquadtree format include
a coordinate system element with the coordinate system in Well Known Text
format. An alternative might be in anything supported for SRS names in the
OGC WxS specifications (such like EPSG:4326 or the OGC URN specifications).
I also would like to see some flexibility in the format of the tiles. At
the very least png, and jpeg. JPEG2000, and TIFF might also be desirable.
TIFF I mention because of the flexibility of pixel data types, and
multispectral support. Of course TIFF is a bit heavy for very small tiles.
You mentioned above about having to sacrifice an RGB color for a nodata
marker with jpeg format, but this doesn't really work because jpeg is so
lossy. So it is essentially impossible to use nodata values with jpeg.
Overall I would have preferred to see a GeoQuadTree format that was also
a valid instance of the url view of a "standard tile cache" per all the
"tile cache standard" work being done by various folks. That would be
super-cool, but perhaps not a high priority for you.
PS. A very nice professional job on the geoquadtree.org web site. But it
lacks in ... humanity. Perhaps an FAQ on who did the work and why?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
