[Gdal-dev] GDAL reentrancy issue
Mir Hassan Ali
mirhassanali at gmail.com
Thu Nov 16 06:22:17 EST 2006
Hi
I am building a small web application in C# that uses a custom assembly(dll)
which in-turn uses the C# wrappers for gdal to read the .shp files (only
read not write).
My question is, since OGR/GDAL is not reentrant (this is what I assume after
reading the post
http://lists.maptools.org/pipermail/gdal-dev/2006-September/010160.html), is
it going to cause any problems to the web application as obviously multiple
users will be using the applications at the same time.
Best Regards
Mir
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061116/9f1fa1ea/attachment.html
