[Gdal-dev] ColorTable in C#
Jean Michel PIERRET jmp at geosys.com
Wed Nov 22 02:48:45 EST 2006
It works very well, thanks.
Best Regards,
PIERRET Jean michel
-----Message d'origine-----
De : Tamas Szekeres [mailto:szekerest at gmail.com]
Envoyé : mardi 21 novembre 2006 22:42
À : Jean Michel PIERRET
Cc : gdal-dev at lists.maptools.org
Objet : Re: RE : [Gdal-dev] ColorTable in C#
When constructing the ColorTable you have to use the GDALPaletteInterp
constants as the parameter like:
ct_out = new ColorTable(gdalconst.GPI_RGB);
Here is the complete code:
public static void test(string file, string file_out)
        gdal.AllRegister();
        Driver dv = null;
        Dataset ds = null, ds_out = null;
        Band ba = null, ba_out = null;
        ColorTable ct = null, ct_out = null;
        byte [] buffer;
        ds = gdal.Open(file, gdalconst.GA_ReadOnly);
        ba = ds.GetRasterBand(1);
        ct = ba.GetRasterColorTable();
        buffer = new byte [ds.RasterXSize * ds.RasterYSize];
        ba.ReadRaster(0, 0, ds.RasterXSize, ds.RasterYSize, buffer,
            ds.RasterXSize, ds.RasterYSize, 0, 0);
        dv = gdal.GetDriverByName("GTiff");
        ds_out = dv.Create(file_out, ds.RasterXSize, ds.RasterYSize,
            ds.RasterCount, ba.DataType, new string [] {});
        ba_out = ds_out.GetRasterBand(1);
        ba_out.WriteRaster(0, 0, ds.RasterXSize, ds.RasterYSize, buffer,
        for (int i = 0; i < ct.GetCount(); i++)
            ColorEntry ce = null, ce_out = null;
            ce = ct.GetColorEntry(i);
            ce_out = new ColorEntry();
            ce_out.c1 = ce.c1;
            ce_out.c2 = ce.c2;
            ce_out.c3 = ce.c3;
            ce_out.c4 = ce.c4
            ct_out.SetColorEntry(i, ce_out);
            ce.Dispose();
            ce_out.Dispose();
        ba_out.SetRasterColorTable(ct_out);
Best Regards,
Tamas Szekeres
2006/11/21, Jean Michel PIERRET <jmp at geosys.com>:
> Hi,
> I'm using the CVS : "gdal-cvs-2006.11.21.tar.gz", I see well the new Class
> ColorEntry, but I still can't create a new ColorTable with 256 ColorEntry.
>         Driver dv = null;
>         byte [] buffer;
>     ct_out = new ColorTable(ct.GetCount());
>                 ce_out.c1 = ce.c1;
>                 ce_out.c2 = ce.c2;
>                 ce_out.c3 = ce.c3;
>                 ce_out.c4 = ce.c4;
>                 ce.Dispose();
>                 ce_out.Dispose();
>         ct_out.Dispose();
>         ba_out.Dispose();
>         ds_out.Dispose();
>         ct.Dispose();
>         ba.Dispose();
>         ds.Dispose();
> De: Tamas Szekeres [mailto:szekerest at gmail.com]
> Envoyé: lundi 20 novembre 2006 14:06
> Ŕ: Jean Michel PIERRET
> Cc: gdal-dev at lists.maptools.org
> Objet: Re: [Gdal-dev] ColorTable in C#
> Hi,
> I've just added the ColorEntry struct for the SWIG C# interface. Now you can
> use
> the ColorTable and ColorEntry classes along with
> Band.SetRasterColorTable and Band.GetRasterColorTable.
> Checkout the latest CVS and notify me how it works.
> Best Regards,
> Tamas Szekeres
> 2006/11/20, Jean Michel PIERRET <jmp at geosys.com>:
> > Hi,
> > How can I create a new ColorTable in C# for a new image.
> > Thank.
> > PIERRET Jean michel.
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
