[Gdal-dev] LOCALE dependent segfault in OGR
Andrey Kiselev dron at ak4719.spb.edu
Fri Nov 24 10:43:35 EST 2006
On Wed, Nov 22, 2006 at 04:54:54PM +0100, Markus Neteler wrote:
> after a new installation of Mandriva 2007 I found some fancy bug (or
> whatever), apparently related to the LOCALE:
Markus,
I have tried to reproduce your problem without success. Also I read your
message more carefully and have few notes.
> 1. DE LOCALE:
> GRASS 6.3.cvs (eu_laea):~/data/vmap0_europe_shape > v.in.ogr europe_countries_LAEA.shp out=europe_countries --o
> WARNUNG: Die Vektorkarte 'europe_countries' existiert bereits und wird
>          überschrieben.
The message above is localized, so the process printing that message
calls setlocale() function.
> A datum name etrs89 (European_Terrestrial_Reference_System_1989) was specified without transformation parameters.
> Note that the GRASS default for etrs89 is towgs84=0.000,0.000,0.000.
These messages are not localized, so the process which prints them
either does not call setlocale() or these messages just do not
translated. It looks like the former is right, because numbers in
towgs84 list are dot delimited. In De locale they should be comma
delimited.
> Die Projektionsinformationen des Eingabedatensatzes und der aktuellen Location stimmen überein.
> Fahre mit dem Import fort...
>          überschrieben.
> Layer: europe_countries_LAEA
> WARNUNG: Spaltenname 'cat' wurde in 'cat_' geändert.
> Importiere 3356 Objekte der Karte...
> Speicherzugriffsfehler
This is localized again.
Actually I do not understand why you have a mix of localized and
non-localized processes here. My own GRASS build (6.3cvs) does not
localized at all, I have EN messages in any locale (probably I should
build GRASS with some option enabled?).
So I am lost here. Markus, do you have any clues on this?
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
