[Gdal-dev] GDAL Xcode project
William Kyngesburye woklist at kyngchaos.com
Fri Nov 24 12:21:37 EST 2006
I finished a GDAL Xcode project, available for download on my site.
This is an alternative to the new framework build option in CVS.
It's much easier to package the framework this way - the build name
doesn't have to go thru libtool, and thus have to be changed at
install, and the folder structure is all automatic.
It's also possible to do a Universal build without fuss.  The
configure method would need fussing with the libtool configuration or
using other workarounds to get both architectures.  In Xcode it's
automatic.  Though it does still need a cpl_config.h patch to switch
endians on the fly (included in the project).
There are sub-projects included to deal with optional formats that
need external libraries.  You should be able to drop all the sources
(GDAL and deps) into the project and easily build a full-featured,
Universal GDAL framework.
See the readme for details.  Note that configuration is manual, but
hopefully easy to understand.  You just change build Settings at the
project level for versions, and prefixes for a few dependencies I
decided didn't belong as sub-projects.
There is also a PROJ framework available.  It also takes care of
Universal build and packaging issues.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
