[Gdal-dev] GDAL licensing
Tamas Szekeres
szekerest at gmail.com
Fri Nov 24 13:09:58 EST 2006
I don't think if SWIG would determine how the generated wrappers are
licensed. Therefore I think the wrappers will inherit the license
style of the underlying project that is: MIT/X.
(http://www.opensource.org/licenses/mit-license)
Best Regards,
Tamas
2006/11/24, Frank Warmerdam <warmerdam at pobox.com>:
> Mir Hassan Ali wrote:
> > Hi
> > If I am using GDAL C# wrappers and MapScript C# wrappers in my
> > application then what will be the licensing issues? Do I need to make my
> > application open source?
> Mir,
> No. MapServer and GDAL are under an MIT/X style license that allows for
> building proprietary applications on top of them. I am not aware of any
> special licensing for the c# wrappers, so you should be fine.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
