[Gdal-dev] ogr2ogr MapINfo bug?
Mateusz Loskot
mateusz at loskot.net
Sat Nov 25 15:27:42 EST 2006
Bill Thoen wrote:
> On Sat, Nov 25, 2006 at 11:24:42AM -0500, Frank Warmerdam wrote:
>> Ah, so the problem is, presumably, that OGR isn't seeing the geometry
>> of the PostGIS tables properly. You might want to verify this with ogrinfo
>> against the postgis table.
> It looks like using an sql statement with ogr2ogr is causing it to miss the
> geometry. When I try ogrinfo on one record, I get these results:
> $ ogrinfo -sql "select * from counties where fips='17055'"
> "PG:dbname=spatial1"
> INFO: Open of `PG:dbname=spatial1'
> using driver `PostgreSQL' successful.
> Layer name: sql_statement
> Geometry: Unknown (any)
> Feature Count: 1
> Layer SRS WKT:
> (unknown)
> Geometry Column = the_geom
> gid: Integer (0.0)
> fips: String (0.0)
> state: String (0.0)
> county: String (0.0)
> OGRFeature(sql_statement):0
> gid (Integer) = 576
> fips (String) = 17055
> state (String) = Illinois
> county (String) = Franklin
> So I'm not sure if this is a bug or I'm just not using the -sql switch
> properly. Can you tell me what's going on and how to fix it?
I tested current GDAL CVS using two versions of PostGIS databases and
layers:
1. When geometry does not include SRID, it is not PostGIS EWKB/EWKT
format, then using -sql option geometry is returned properly but
with Unknown type:
mloskot:~$ ogrinfo -sql "select * from point where ogc_fid=1"
PG:dbname=gdal_test
INFO: Open of `PG:dbname=gdal_test'
Feature Count: 1
Extent: (19.769250, 51.446583) - (19.769250, 51.446583)
Layer SRS WKT:
(unknown)
FID Column = ogc_fid
Geometry Column = wkb_geometry
recnum: String (0.0)
lat: String (0.0)
lon: String (0.0)
altitude: String (0.0)
longname: String (0.0)
OGRFeature(sql_statement):1
recnum (String) = 1
name (String) = STATOIL
lat (String) = +51,4465833
lon (String) = +19,7692500
altitude (String) = 215
longname (String) = STACJA BENZ
POINT (19.76925 51.446583333333336)
But then I query the same layer and feature using -where option,
it returns geometry type properly:
mloskot:~$ ogr/ogrinfo PG:dbname=gdal_test -where "ogc_fid=1" point
Layer name: point
Geometry: Point
Feature Count: 1
Extent: (11.660233, 48.320915) - (21.675484, 53.763435)
Layer SRS WKT:
(unknown)
altitude: String (6.0)
lat: String (12.0)
lon: String (12.0)
longname: String (17.0)
recnum: String (6.0)
OGRFeature(point):1
recnum (String) = 1
POINT (19.76925 51.446583333333301)
2. The second test I did was against layer with SRID definition, so
EWKB/EWKT stream is returned:
mloskot:~/dev/gdal/_cvs/gdal$ ogr/ogrinfo PG:dbname=ewkb_test ewkt_srid
-sql "select * from ewkt_srid where id=9"
INFO: Open of `PG:dbname=ewkb_test'
layer names ignored in combination with -sql.
Feature Count: 1
Layer SRS WKT:
(unknown)
Geometry Column = egeom
id (Integer) = 9
As yo can see, Geometry is still Unknown.
Next,after I define export CPL_DEBUG=ON environment variable, I get
debug message:
OGR: OGRGeometryFactory::createFromWkb() - got corrupt data.
Frank, I suppose the problem is that -sql query with asterix retrieves
data as EWKB, because OGC functions AsBinary or AsText are not used,
so PostGIS internal format is returned.
Do you have similar considerations?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
