[Gdal-dev] warping NITF file with RPCs and losing color
Tue Nov 28 20:46:21 EST 2006
Derrick Hoffman wrote:
> Hello all,
> I am trying to warp an NITF file using GDAL warp.  The file has RPCs and
> the coordinate warping itself works just fine.  The problem is that
> after the warp occurs, the result image is now grayscale.  Is there any
> way to preserve each band’s colors in the output file?
Derrick,
First, I'd warn you that GDAL warps using RPCs aren't very accuracy since
I believe an elevation of zero is assumed everywhere.
I'm not sure why you are losing the color of your file.  Generally speaking
current versions of gdalwarp will try and copy a pseudocolor table to the
output file if the source has one, and 3-band RGB files should be fine.
Can you provide a gdalinfo report on the input file and output file, and
the version of GDAL you are using?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
