[Gdal-dev] gdalwarp reprojection error
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 28 20:47:56 EST 2006
Gong, Shawn wrote:
> Hi list,
> I tried to reproject an IKONOS image from UTM to lat/lon using gdalwarp.
> The following error message appeared:
> gdalwarp -t_srs "+proj=latlong +datum=WGS84" src.tif target.tif
> ERROR 1: Too many points (441 out of 441) failed to transform, unable to
> compute output bounds.
Shawn,
Can you provide a gdalinfo report on the input file?
Is there any chance you don't have PROJ.4 built on your system?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
