[Gdal-dev] GDAL/OGR-1.3.2 and ogrinfo.exe
Mateusz Loskot mateusz at loskot.net
Wed Nov 29 13:34:51 EST 2006
Jean-Daniel GONON wrote:
> Hi
> I could solve my last problem, I thought  it was because of XERCES-C
> 2.7.0 (but it was a bad include library).
> Now, I have an other problem, still about GDAL/OGR-1.3.2 (in original
> version, with XERCES-C 2.7.0 moreover).
> Compilation of gdal.DLL is good, but using of gdal.dll by ogrinfo.exe
> generates two errors in "C:\Program Files\Microsoft Visual Studio .NET
> 2003\Vc7\crt\src\dbgheap.c" file (at the lines 1132 and 1138).
Jean,
This error indicates there must be a bug somewhere that causes heap
corruption. The assertion caught in dbgheap.c file comes from free()
function and says something like this:
"you're trying to free block of memory that can't be deallocated because
of invalid type - not deallocable block."
Unfortunately, without more details, I can't see how to track the
problem down and to find where is the problem in GDAL/ogrinfo.exe.
Could you provide more details about:
1. How did you compile GDAL? Using provided makefile.vc?
2. What operation do you do using ogrinfo.exe?
3. What dataset do you use and can you provide them for testing?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
