[Gdal-dev] GDAL CPLError and C++ Exceptions
Chapman, Martin
MChapman at sanz.com
Wed Nov 29 17:01:31 EST 2006
Ivan,
Looks good to me. If you're using COM though, what might be better is
if you return an error message with something like Error() if your
object implements ISupportErrorInfo. That way you know what GDAL didn't
like about your file name.
// example pseudo code
if (m_Dataset == NULL)
Error((char*) CPLGetLastErrorMsg(), __uuidof(Ixxxxx));
return E_FAIL;
Martin Chapman
Software Developer
http://www.earthwhere.com
W - 303.495.6326
C - 303.898.0397
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Ivan Lucena
Sent: Tuesday, November 28, 2006 8:45 AM
To: Gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] GDAL CPLError and C++ Exceptions
Hi Matt, Martin, Frank, all,
>> simply check error status after each GDAL call...
That looks like that is the right thing to do. I just want to share the
following piece of code with you guys where I am trying to use the same
approach. I would like to know if I am going in the right direction, if
you don't mind to take a quick look.
// A C++ method:
try
m_Dataset = (GDALDataset*) GDALOpen(pszFileName, GA_ReadOnly);
return E_FAIL;
return S_OK;
catch(...)
return E_FAIL;
I have debugged it a lot, forcing the error with invalid inputs (null
pointer, invalid file name, invalid network address, etc.), and the
result is that the caller of that method receives the exception nicely
jumping to his own exception handler to do his own stuff as I would like
it to do.
Thanks in advance,
Ivan
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matt Hanson
Sent: Tuesday, November 28, 2006 10:17 AM
Ok thanks, that answers my question. I was thinking I could write my
own error handlers but sounds like that is not a good idea and I just
need to simply check error status after each GDAL call. Martin - thanks
for the tips in the other posts.
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Mon 11/27/2006 8:35 PM
To: Matt Hanson
Cc: Gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] GDAL CPLError and C++ Exceptions
Matt Hanson wrote:
> Hi, I recently got hung up on tracking down an GDAL error because I'm
not
> handling errors from CPLError. I'd like to be able to handle those
errors
> and create C++ Exceptions but I'm not clear on how to do so. Anyone
have
> any code examples for how I might turn CPLErrors into Exceptions? It
looks
> like I should probably set the error handler, but what should that
function
> look like? Would it simply examine the contents of the GDAL Error
number
> and message and decide to throw or not throw an exception? (which
would then
> be presumably caught in a user's application).
Matt,
I just wanted to add a couple things:
o You can also install your own error handlers to be called by
CPLError().
You can find some more information about this at:
http://www.gdal.org/cpl__error_8h.html
o However, you should generally *not* throw exceptions from within
such
an error handler, as GDAL does not guarantee proper cleanup in the
face
of an exception deep in the internals. At the very least you are
likely
to see memory leaks, and quite possible data structures could be
left
in an improper state. If you want to throw exceptions, it is best
to do
it after the GDAL calls, as shown in the other email.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | President OSGeo,
http://osgeo.org <http://osgeo.org/>
Gdal-dev mailing list
http://lists.maptools.org/mailman/listinfo/gdal-dev
