[Gdal-dev] WCS Client Driver
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Oct 4 13:45:37 EDT 2006
(jumping up and down -- good news!).
This will undoubtedly increase the usage of WCS servers.
Though I'm not a part of the PSC, I provide the following comments
(interleaved):
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
> Frank Warmerdam
> Sent: 04 October, 2006 1:13 PM
> To: gdal-dev
> Subject: [Gdal-dev] WCS Client Driver
> Folks,
> I have received client funding for a new driver for GDAL,
> with GDAL acting as a WCS client. The proposal (less the
> pricing) is included below. Normally, I'd just launch into
> something like this and announce it upon completion, but it
> occurs to me that perhaps I should be requesting permission
> from PSC to add a new driver since it represents "Adding a
> substantial amount of new code" per RFC 1. I'm not sure this
> needs to be written as an RFC though.
> So, I hereby request permission from the GDAL PSC to
> implement the below described read-only WCS client driver.
> Feedback on technical details is also welcome.
> WCS Client Driver for GDAL
> Purpose
> To implement a new GDAL driver for accessing a remote WCS
> coverage in a manner analygous to any local raster dataset.
> Technical Details
> Overall
> The WCS coverage driver will read a service description file
> to establish the parameters it requires to make GetCoverage
> calls on a WCS server. If the the service description file
> lacks DescribeCoverage information for the coverage, the
> driver will invoke DescribeCoverage, and fill in the service
> description file on disk.
In terms of MapServer, this is a bit different than the other OWS client
approaches (i.e. the code is in MapServer itself for WMS, WFS client).
I would be interested in how this functionality will "roll up" to
MapServer and what the relationship is. Just want to make sure there
are little/no duplications.
> Specification Features
> Version:
> o The driver will support WCS version 1.0.0.
> o The driver will support WCS version 1.1.0 based on
> current draft. (Phase 2)
I'm pretty sure 1.1.0 implements the owsCommon specification. It would
be valuable when implementing anything from owsCommon that it can be
reused in some way. I could see this being leveraged in MapServer (even
as a code copy/paste) for the logic.
> o The driver will *not* support WCS version 0.7.
> Encodings:
> o The driver will support GET keyword/value requests.
> o The driver will *not* support POST XML requests.
> Georeferencing:
> o The driver will support coordinate systems defined only
> in "EPSG:xyz",
> "AUTO:xyz" or "OGC:xyz" formats, not GML CRS encodings.
> o The driver will support georeferencing information for
> grids only if
> it is presented as a RectifiedGrid element in the
> DescribeCoverage.
> NullValues:
> o The driver will support only one "singleValue" null
> values. It will
> not support multiple singleValues, nor intervals.
> SupportedFormats:
> o The driver will support images returned in GeoTIFF, DTED and NITF
> formats. Other formats will also be supported if GDAL
> drivers exist
> (such as HDF-EOS if GDAL is configured with HDF-EOS
> format support).
> At this time GML coverage responses will *not* be supported.
> o The driver will support multi-part mime bundles as a mechanism to
> return multiple files (such as JPEG+world file). (Phase 2)
> Interpolation:
> o The driver will default to use of nearest neighbour interpolation.
> Time/Parameter Support:
> o Supported via overrides in the Service Description File.
> The service description file is an XML format file that can
> hold all the information GDAL requires to access a WCS
> coverage, as well as various optional items that can be used
> to control particular behaviors.
> It may include:
> 1) The service URL - the base url to which DescribeCoverage and
> GetCoverage requests is made.
> 2) The result of the DescribeCoverage request for the
> coverage. This
> includes the spatial extents, and resolution.
> 3) Override values for various parameters, including interpolation,
> and request format.
> 4) The pixel data type for the coverage.
> 5) Request values for time and other parameter dimensions.
> 6) The coordinate system in Well Known Text format
> (overrides coordinate
> system information in the DescribeCoverage).
> 7) The geotransform for the coverage (overrides values in the
> DescribeCoverage).
> 8) A preferred block size, and other reading strategy
> information that
> may affect performance.
Frank: you may want to look at what we did for the OWSContext work for
binding to a WCS in a context doc.
> Remote Access Strategies
> Getting respectable performance for client applications
> accessing remote WCS servers will in large part depend on the
> approach taken to turning local requests into remote
> requests. In particular, because some GDAL client
> applications take a fine grained approach to requesting data
> from drivers, it can be very helpful to aggregate several
> requests based on some blocking scheme. But other
> applications may make single large read requests of exactly
> all the data required. It is desirable to handle these as a
> single request to the remote WCS server that pull back just
> the desired data.
> Because the of diversity of situations several read
> strategies will be supported.
> 1) Block oriented with caching. All requests to the remote
> server will made based on the block size, and the blocks will
> be cached normally in the GDAL memory block cache. The
> default block size should be substantial, perhaps 2MB blocks
> the width of the image.
> 2) 1:1 RasterIO() to GetCoverage. Each RasterIO() request
> will result in a remote GetCoverage request at the resolution
> and for the exact region requested. Because of the irregular
> nature of requests, caching is impractical.
> 3) Hybrid. Block oriented with caching will be used for
> smallish requests, while very large RasterIO() requests will
> be done as an immediate call but expanded to block boundaries
> and the result pushed into the block cache. The benefit is
> that several blocks may be handled in a single request.
> The default operation will be to use the Hybrid mode.
> Specific strategies and block sizes can be forced via the
> service description file.
> Overviews
> WCS servers will be represented to the client application as
> having power of 2 reduced resolution overview layers. When
> using block oriented IO, requests will be made at reduced
> resolutions based on the overview levels when appropriate.
> Other Issues
> 1) The DescribeCoverage information does not include any clue
> as to the actual pixel data type of data. In order for
> GDALOpen() to return for a WCS based on a service description
> file that contains only the url, it will be necessary to
> perform a DescribeCoverage(), and also to fetch a small
> sample file to establish the pixel data type.
> 2) GDAL currently supports opening several file formats from
> "in memory"
> buffers. Other file formats do not support this. As part of
> this project, the driver will first attempt to open the
> returned datasets using the in-memory mechanism. If that
> fails, the data will be written to a temporary file on disk
> for access. Suitable logic for placing temporary files will
> be needed.
> 3) The WCS client capability will need to be able to do
> remote HTTP requests.
> I have used the curl open source library
> (http://curl.haxx.se/libcurl) in several projects very
> successfully, and would plan to use it for GDAL WCS as well.
> It will be a requirement for building the WCS support.
> Testing
> The WCS client will be tested against several WCS servers,
> including hopefully UMN MapServer, IONIC Red Spider,
> Cubewerx, and PCI Geomatics WCS servers. The GDAL "autotest"
> suite will also be extended with test scripts for the WCS
> client driver operating against stable public WCS servers.
> Documentation
> Standard "user" documentation will be written for the WCS
> driver in HTML format. It will include a detailed
> specification for the service description file, and all it's
> parameters.
> Intellectual Property
> The WCS driver will become a regular part of the GDAL
> library, and it's source code and documentation will be
> released under the normal GDAL open source license.
> Timetable
> Phase 1 (essentially WCS 1.0.0) will be completed within 5
> weeks of project approval.
> Phase 2 (WCS 1.1.0) will be completed within 7 weeks of phase
> 1 completion if approved.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
