[Gdal-dev] OGDI driver with GDAL-ogr
Reiner Beck
R.Beck at m4com.de
Tue Oct 10 08:55:55 EDT 2006
Yves,
the VRF driver is sensitive against mixed case pathnames. This is due to
some complex name mangling when accessing the data set. Try to move the
data to a path with all lowercase directories; e.g.
"/home/yjacolin/v0eur/vmaplv0/eurnasia".
You can search the GDAL mailing list archive for more info by using the
keyword "vmap". Look for the thread "[Gdal-dev] ogr2ogr issues for vmap0
on Ubuntu Breezy".
HTH
Cheers
Reiner
> Hi again !
> Sorry, I wrote too fast. The driver is working, but I always 0 feature ! Here
> my command :
> ogrinfo -ro -summary
> gltp:/vrf/home/yjacolin/Documents/SIG_local/Echange/Recu/v0eur/vmaplv0/eurnasia
> 'polbnda at bnd(*)_area'
> Any idea ?
> Y.
> Le Mardi 10 Octobre 2006 10:51, Jacolin Yves a écrit :
>> Hello,
>> I try to build GDAL-OGR with the OGDI driver. I want to use VMAP0 and
>> transform these layers to shapefile then in mapserver.
>> First I try to use the libogdi binaire from my distribution (Mandriva2006).
>> I success to connect to but I get 0 feature ! Altough in VPFviewer I get
>> much more.
>> After looking for in the mailing list, I read that my OGDI driver may be a
>> little bit too old, so I build the last one (OGDI-3.1.5). I build again
>> gdal-ogr and ... altough all seems ok, I get this error message :
>> [yjacolin at TI-PC2 ~]$ gdalinfo
>> Exception en point flottant
>> I can not translate this, because I do not understand it in french :-/,
>> something like "exception in floating point" may be?!
>> Anybody can help me ? Thanks in advance.
>> Y.
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
