[Gdal-dev] troubleshooting "Option -prjwin incomplete,
or not recognised."
Matt Wilkie
matt.wilkie at gov.yk.ca
Thu Oct 12 13:56:54 EDT 2006
Hi all,
I'm trying to extract a subset of a PCI .pix image with gdal_translate
but I keep getting the error "Option -prjwin incomplete, or not
recognised.". What is wrong with my command syntax?
>> gdal_translate -prjwin 527609.250, 6699639.000 562350.500,
6667716.500 -outsize 600 600 bigass.pix test.tif
Option -prjwin incomplete, or not recognised.
Usage: gdal_translate [--help-general]
[-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
...snip...
gdalinfo for the source image reports:
>> gdalinfo bigass.pix
Driver: PCIDSK/PCIDSK Database File
Size is 138965, 127690
Coordinate System is:
PROJCS["UTM Zone 8, Northern Hemisphere",
...blah blah...
Metadata:
SOFTWARE=PACEV9.1
...blah blah...
Corner Coordinates:
Upper Left ( 492868.000, 6731561.500) (135d 7'50.57"W, 60d43'10.52"N)
Lower Left ( 492868.000, 6667716.500) (135d 7'42.36"W, 60d 8'46.84"N)
Upper Right ( 562350.500, 6731561.500) (133d51'26.58"W, 60d42'53.22"N)
Lower Right ( 562350.500, 6667716.500) (133d52'38.36"W, 60d 8'29.94"N)
Center ( 527609.250, 6699639.000) (134d29'54.44"W, 60d25'55.53"N)
Band 1 Block=138965x1 Type=Byte, ColorInterp=Undefined
...blah blah...
note that in this example I extracted the projwin coordinates from the
gdalinfo center point and the lower right.
thanks in advance for your time.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
