[Gdal-dev] how to translate .asc files (Info ASCII Grid) to .dem
files (USGS ASCII DEM)
maestrini_andrea at virgilio.it
Tue Oct 17 06:02:17 EDT 2006
Hello gdal-dev,
I'm very new to gdal so please cope with my ignorance.
I have two questions for you
1. .dem files are same things SRTM files
(used by Radio Mobile Radio Propagation tool)???
2. when I invoke the
command:
./gdal_translate -of USGSDEM input.asc output.dem
I have
this error:
Input file size is 6592, 5728
ERROR 1: DEM Default Setup:
Importing source dataset projection failed
what it means?
Is the
command right?
Can I translate a file .asc into a file .dem and How I
can do it????
Thank you,
Andrea
