[Gdal-dev] SRTM .hgt generation
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 18 09:31:05 EDT 2006
maestrini_andrea at virgilio.it wrote:
> Hi!
> Can you help me in converting .dem format into .hgt format (for
> Radio Mobile tool that used SRTM maps )?
> I have converted .asc format
> in .dem format with Gdal, but Radio Mobile works with SRTM format
> (Radio Mobile uses .hgt format) it doesn't work with .dem!!!
Andrea,
I *think* that .hgt files are just raw 16bit raster files with a particular
product size and a particular resolution/extent. This could be produced by
GDAL but I don't know the srtm particulars off hand.
OK, I skimmed the GRASS r.in.srtm script for particulars, and I it looks like
SRTM .hgt files are 1 degree by 1 degree files of 1201 x 1201 pixels, with
16bit data. The files seem to be named stuff like e100s10.hgt.
To produce something like the e100s10.hgt file you should be able to do
something like:
gdalwarp -of EHDR -ot Int16 -te 100 9 101 10 -ts 1201 1201 -rb \
in.tif e100s10.hgt
then delete e100s10.hdr, and e100s10.prj which you shouldn't need.
Ah, shoot, I see that .hgt files need to be in big endian order which is
not the default for the EHDR writer. So in fact you will need to do:
in.tif e100s10.hgt
edit e100s10.hdr, modify "BYTEORDER I" to "BYTEORDER M" and then rerun
the warp:
gdalwarp -of EHDR -rb in.tif e100s10.hgt
You will need to take care to produce only tiles for regions you have input
data for.
I have taken the liberty of cc:ing gdal-dev in case this is of interest to
others.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
