Ben Discoe wrote: > The makefile.vc file would need a lot of other work to produce correct and > suitable VC8 DLLs. Again, avoid it if possible. Ben, Here is the whole procedure of embedding manifest using nmake explained: http://msdn2.microsoft.com/en-us/library/ms235591.aspx Cheers -- Mateusz Loskot http://mateusz.loskot.net
