[Gdal-dev] ogrinfo and sql option
Bryan Keith
bryan at geomega.com
Mon Oct 23 12:29:17 EDT 2006
Matt,
I haven't used windows xp, but I use unxutils (grep is included) on a
windows 2000 machine with ogr
http://sourceforge.net/projects/unxutils/
I don't know if dbview (or other dbf to ascii executables) are available
for windows.
Bryan
matt.pettis at thomson.com wrote:
> They do... I'm trying this all out on windows xp, so I'll have to
> modify, but those are good ideas.
> Thanks,
> matt
> -----Original Message-----
> From: Bryan Keith [mailto:bryan at geomega.com]
> Sent: Monday, October 23, 2006 11:21 AM
> To: Pettis, Matthew (TLR Corp)
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] ogrinfo and sql option
> Matt,
> I don't know if you can do that with an sql string or where clause in
> ogrinfo, but you could use grep to remove all ogrinfo output that
> contained the word LINESTRING, e.g.:
> ogrinfo myfile.shp -al | grep LINESTRING -v
> I also sometimes use a tool called dbview to look at data in dbf files.
> Maybe those ideas help.
> Bryan
>> Is there a way to use ogrinfo to get a listing of just the .dbf
>> attribute values without listing the line/polygon coordinates with
> them?
>> my coordinate sets are large, and i am interested in exploring the
>> .dbf values of my shapefiles.
>> Thanks,
>> Matt
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
