[Gdal-dev] Visual Studio 2005, GDAL and Manifests
Simon Perkins sy at perkins.net
Wed Oct 25 10:07:28 EDT 2006
Simon Perkins wrote:
> Yes, I see that the naming convention idea does help significantly
> here. One question: do you build GDAL and then manually copy the DLLs
> from the release or debug directories (as appropriate) into a common
> directory that is on your PATH? Or do you modify the GDAL build
> configurations so that both debug and release versions get built in
> the same directory, and then put _that_ on your path (if that is even
> possible)? I'm just trying to automate as much as possible...
Or do you put both debug and release build directories on your PATH?
Sy
